| 艾讯宏达最新推出强固型无风扇嵌入式系统GT6020/360 |
| 2005-5-25 10:57:00 艾讯宏达科技有限公司 供稿 |
GT6020/360 Fanless Embedded System with Intel ULV Celeron 400MHz Processor
·Fanless operation ·Supports Intel ULV Celeron 400MHz processor ·Unique mechanical design for thermal solution ·High performance with extremely low power ·Full feature I/O ·Supports PC/104+, CompactFlash ·PCI slot expansion support ·Three LAN port ·One 2.5"/3.5” HDD drive bay ·90watt AC-in power supply ·Desktop or wall mount Specification Standard Color: White Construction: Aluminum die-casting and heavy-duty steel System: SYS7360V3EA System Memory: 184-pin DDR DIMM max. up to 1GB System I/O Outlet: 9-pin D-Sub male connector,COM1,3,4 for RS232 9-pin D-Sub male connector, COM2 for RS485/422/232 15-pin D-Sub female connector for VGA 25-pin D-Sub female connector for LPT RJ45 connector for 10/100Base-T Ethernent USB connector Vac 100 -240 power input connector Extension 2.5"/3.5" HDD drive bay CompactFlash Type II slot PC104/PC104+ module expansion slot PCI slot System Indicator green LED for system power-on orange LED for HDD active Power Supply Input rating:Vac 100-240 universal/1Amp, Output rating: 100 Watt, Output voltage: +5VDC 10A, +12VDC 3A Environmental Operating temperature: 0oC to 50oC Storage temperature: -25oC to +80oC Humidity:10-90% RH (no condensation) Vibration endurance:2Grms w/CF(5-500Hz,X,Y,Z directions) 0.5Grms w/HDD(5-500Hz,X,Y,Z directions) Certification:CE Dimensions:220mmx280mmx90mm (WxDxH) EOS Support:XPE, WinCE, Linux Optional Compact Flash:32M,64M,128M,256M,512M 2.5" HDD:20G,40G DDR DIMM:256M,512M |
| 在线联系该厂商: |
| 关于“艾讯宏达最新推出强固型无风扇嵌入式系统GT6020/360”,我有如下需求或意向: |
