| 艾讯宏达 最新推出UFO6368S 无风扇嵌入式计算机系统 |
| 2006-8-17 9:16:00 艾讯宏达科技有限公司 供稿 |
UFO6368S AMD Geode Castle Fanless System w/VGA/Audio/1394/CF/Mini-PCI/LANx2
FEATURES: · Supports AMD Geode LX800 400/500 MHz with 128 KB L2 cache · AMD Geode⑩ CS5536 companion chip · Dual 10/100 Fast Ethernet LAN Ports (VIA VT6105) · USB 2.0 x 4/VGA/IEEE 1394/Audio Out interface · Onboard Mini-PCI socket for Wireless LAN connection · 4 Serial Ports with RS232 support only SPECIFICATIONS: · Construction Aluminum chassis with fanless Design · Dimension 195 mm (W) x 150 mm (D) x 80 mm (H) · Mainboard Supports AMD Geode LX800 500 MHz with 128 KB L2 cache; AMD Geode CS5536 companion chipn; AMD Geode Castle 500MHz w/ 128KB L2 cache · Main Memory Supports one 184-pin Non-ECC Non-Registered DDR DIMM, Max up to 1 GB · Device n On-board CompactFlash socket x 1; Internal 2.5” HDD drive bay x 1; · Expansion Slot PC/104-Plus (without -12 V and -5 V); Mini-PCI Socket x 1; · I/O Interface Front I/O Ports; HDD Access/Power/LAN status LED (Act/Link; Speed); Programmable Alarm LED; Programmable Status LED; USB 2.0 x 4 portsn Serial port x 2; Rear I/O Ports; Parallel port x 1; PS/2 Keyboard/Mouse x 1; IEEE1394 port x 1; Serial port x 2; Audio out x 1; 10/100 Ethernet LAN x 2; VGA connector x 1; DC power +12 V input x 1 ·Operating temperature: 0∑C to 40∑ ·Relative humidity: 10% to 90% (Non-condensing) |
| 在线联系该厂商: |
| 关于“艾讯宏达 最新推出UFO6368S 无风扇嵌入式计算机系统”,我有如下需求或意向: |
