Untitled Document
Untitled Document
超微型嵌入式电脑模块
名片型嵌入式电脑模块
2.5英寸嵌入式电脑模块
PC/104嵌入式模块
PC/104周边模块
3.5英寸嵌入式电脑模块
ISA半长工业电脑模块
ATX嵌入式电脑模块
其他产品
参展讯息
研讨会
ICOP Vega86-6270 嵌入式主板
128MB/2S/2USB/VGA/LCD/AUDIO/LAN
规格:
CPU VIA Mark CoreFusion 533MHz
Chipset VIA VT82C686B
BUS PC/104 standard compliant
BIOS AMI BIOS
System Memory Onboard 128MB SDRAM
Cache L1:64KB L2:64KB
VGA Integrated 2D/3D AGP4X graphics with MPEG2
Accelerator
Shared system memory 8M/16M/32M
VGA, SVGA, XGA, SXGA and DSTN/TFT Flat Panel interface support
LAN Realtek 8100B 10/100Mbps Ethernet Controller
Half/Full duplex capability
Audio VIA VT1612A AC97 Codec
Full compatible with AC97 2.2 version
Flash Disk Support MSTI EmbedDisk Module (16MB and above)
PQI DiskOnModule (16MB and above)
I/O Interface Enhanced IDE port (UltraDMA-100 / 66/ 33) x1
FDD port x1
RS-232 port x1
RS-232/485 port x1
Parallel port x1
USB port x2 (Ver 1.1)
10/100Mbps Ethernet port x1
Connectors 2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 34-pin box header for FDD x1
2.0mm 4-pin wafer for Line-in x1
2.0mm 4-pin wafer for Line-out x1
2.0mm 26-pin box header for Printer x1
2.0mm 10-pin box header for RS-232 x2
2.0mm 10-pin box header for USB x1
2.0mm 10-pin box header for VGA x1
2.0mm 8-pin header for Ethernet x1
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin header for Mouse x1
2.54mm 2-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
Power Requirement Single Voltage +5V @ 2.2A
Weight 210g
Packing List
Vega86-6270 x1
CD for User’s Manual & Driver x1
Cable
HDD 44P (2.Q) x1
FDD (2.Q) x1
PRINT (2.Q) x1
RS-232 (2.Q) x2
VGA (2.Q) x1
NET 4x2 (2.Q) x1
USB (2.Q) x1
PS2 KB White x1
PS2 KB (TEST) Black x1
Audio cabel x2
Screw Kit x1
Ordering Information
Vega86-6270 Vega86 PC/104 CPU Module with 128MB SDRAM
Untitled Document
    深圳市昭营科技有限公司
地 址:  深圳市南山区科技园中区科发路2号9栋3层 传 真:  +86-(755)-2650-5111
电 话:  +86-(0755)-2650-0777 +86-(0755)-2650-1777 E-mail:  info@icop.com.cn
 址:  http://www.icop.com.cn/
    昭营(ICOP)科技(上海)
地 址:  上海市漕河泾高科技园区古美路1515号19栋902室 电 话:  021-54451777  传真:021-54451767
    昭营(ICOP)科技(西安)
地 址:  西安市高新区科技路48号创业广场A502 电 话:  029-87997777  传真:029--87997666
