Untitled Document
Untitled Document
超微型嵌入式电脑模块
名片型嵌入式电脑模块
2.5英寸嵌入式电脑模块
PC/104嵌入式模块
PC/104周边模块
3.5英寸嵌入式电脑模块
ISA半长工业电脑模块
ATX嵌入式电脑模块
其他产品
参展讯息
研讨会
ICOP-昭营 VSX-6154嵌入式单版电脑
SoC:
DM&P SoC CPU Vortex86SX- 300MHz
Real Time Clock with Lithium Battery Backup
Cache:
L1:16K I-Cache, 16K D-Cache
Bus:
PC/104 standard compliant
BIOS: AMI BIOS
System Memory: 32MB/64MB/128MB DDR2 on board
规格
SoC
Cache
Bus
PC-104, PC/104+ (Optional)
BIOS
AMI BIOS
System Memory
128MB DDR2 onboard
Watchdog Timer 0 & 1 Sets
Software programmable from 30.5 µsec. To 512 sec. x 2 sets (Watchdog 1 fully compatible with M6117D
VGA
XGI Volari Z9s Chipset
VGA and TFT Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1280 x 1024, 16M colors
LAN
Integrated 10/100Mbps Ethernet
Flash Disk Support
Onboard 2MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
I/O Interface Enhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/422/485 port x1
USB port (Ver2.0) x2
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors
2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x1
2.0mm 10-pin box header for VGA x1
2.0mm 10-pin box header for USB x1
2.0mm 10-pin box header for RS-232 x4
2.0mm 8-pin header for Ethernet x1
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin box header for Mouse x1
2.54mm 7-pin header for Redundancy Signal x1
2.54mm 4-pin header for -5V, -12V, +12V, GND, DC-in x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
2.54mm 2-pin header for System-Fail-SW x1
1.25mm 6-pin wafer for JTAG x1
Power Requirement
Single Voltage +5V @ 580mA
Weight
83g
Board Size
90 X 96mm (3.54 x 3.77 inches)
Operating Temperature
-20°C ~ +70°C
-40°C ~ +85°C(Optional)
Untitled Document
    深圳市昭营科技有限公司
地 址:  深圳市南山区科技园中区科发路2号9栋3层 传 真:  +86-(755)-2650-5111
电 话:  +86-(0755)-2650-0777 +86-(0755)-2650-1777 E-mail:  info@icop.com.cn
 址:  http://www.icop.com.cn/
    昭营(ICOP)科技(上海)
地 址:  上海市漕河泾高科技园区古美路1515号19栋902室 电 话:  021-54451777  传真:021-54451767
    昭营(ICOP)科技(西安)
地 址:  西安市高新区科技路48号创业广场A502 电 话:  029-87997777  传真:029--87997666
