Untitled Document
Untitled Document
超微型嵌入式电脑模块
名片型嵌入式电脑模块
2.5英寸嵌入式电脑模块
PC/104嵌入式模块
PC/104周边模块
3.5英寸嵌入式电脑模块
ISA半长工业电脑模块
ATX嵌入式电脑模块
其他产品
参展讯息
研讨会
ICOP Vega86-6247-6S 嵌入式单板电脑
256MB/6S/3USB/VGA/AUDIO/LCD/LAN/CF
规格:
CPU VIA Mark CoreFusion 533MHz
Real Time Clock with Lithium Battery Backup
Chipset VIA VT82C686B
Bus PC/104 standard compliant
BIOS AMI BIOS
System Memory Onboard 256MB SDRAM
Cache L1:64KB L2:64KB
VGA Integrated 2D/3D AGP4X graphics with MPEG2
Accelerator
Shared system memory 8M/16M/32M
VGA,SVGA, XGA, SXGA and DSTN/TFT Flat Panel interface support
LAN Realtek 8100B 10/100Mbps Ethernet Controller
Half/Full duplex capability
Flash Disk Support MSTI EmbedDisk Module (16MB and above)
I/O Interface Enhanced IDE port (UltraDMA-100 / 66 / 33) x1
FDD port x1
RS-232 port x5
RS-232/485 port x1
Parallel port x1
USB port x3 (Ver 1.1)
10/100Mbps Ethernet port x1
2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD connector x1
2.0mm 34-pin box header for FDD x1
2.0mm 26-pin box header for Printer x1
2.0mm 10-pin box header for RS-232 x5
2.0mm 10-pin box header for USB x1
2.0mm 4-pin wafer for Line-in/Line-out/MIC-in x3
2.54mm 5-pin box header for Keyboard x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
2.54mm 4-pin header for +12V, -12V, -5V DC-in x1
External 15-pin D-Sub female connector for VGA x1
External 9-pin D-Sub male connector for RS-232 x1
External RJ-45 connector for Ethernet x1
External USB connector for x1
External Mini DIN socket for Keyboard/Mouse x1
Type I/II Compact Flash slot x1
Power Requirements Single Voltage +5V @2250mA
Weight 290g
Board Size 102 X 144mm (4.01 x 5.67 inches)
Operating Temperature -20°C ~ +60°C
Packing List
Vega86-6247-6S x1
CD for User’s Manual & Driver x1
Cable
HDD 44P (2.Q) x1
FDD (2.Q) x1
PRINT (2.Q) x1
RS-232 (2.Q) x5
USB (2.Q) x1
Audio Line x1
YKB x1
Ordering information
Vega86-6247-6S Vega86 Half-Size CPU Module with 256MB SDRAM
Untitled Document
    深圳市昭营科技有限公司
地 址:  深圳市南山区科技园中区科发路2号9栋3层 传 真:  +86-(755)-2650-5111
电 话:  +86-(0755)-2650-0777 +86-(0755)-2650-1777 E-mail:  info@icop.com.cn
 址:  http://www.icop.com.cn/
    昭营(ICOP)科技(上海)
地 址:  上海市漕河泾高科技园区古美路1515号19栋902室 电 话:  021-54451777  传真:021-54451767
    昭营(ICOP)科技(西安)
地 址:  西安市高新区科技路48号创业广场A502 电 话:  029-87997777  传真:029--87997666
